Help Please ; 2007 JCB 3C LL Skiploader
reddrew
New User
When i drop the drag or when the tractor is under a load it is like the clutch is on, but there is no clutch on this tractor, only a button on the shifter that interrupts the transmission, to allow shifting. When I slightly apply the brake, all four wheels engage and the tractor works fine. Seems like the brakes are un-interrupting the transmission. I can only drag the gannon, or use the bucket if the brakes are lightly on, yet i can drive down the road and the tractor works fine, no brakes applied.. So perplexed, because tractor is a work horse.. What could this be..
Thank you so.... In advance.. :?:
As posted, wrong forum for a JCB. The Crawlers, Dozers, Loaders and Backhoes Forum may get your problem the most exposure, since your unit fits in that type equipment.
