When i drop the drag or when the tractor is under a load it is like the clutch is on, but there is no clutch on this tractor, only a button on the shifter that interrupts the transmission, to allow shifting. When I slightly apply the brake, all four wheels engage and the tractor works fine. Seems like the brakes are un-interrupting the transmission. I can only drag the gannon, or use the bucket if the brakes are lightly on, yet i can drive down the road and the tractor works fine, no brakes applied.. So perplexed, because tractor is a work horse.. What could this be..
Thank you so.... In advance.. :?:
