John Deere 4230 PTO Lever Loose
Josh8906
I have a 1977 JD 4230 that the PTO Lever is loose and I have to hold it in place with a bungee cord to keep from engaging and disengaging. Does anybody know what may be causing this and how to fix it? Thanks for any help!
If your tractor has quad-range trans more than likely arm encircled in blue on clutch control valve is bent.
