2359 power steering
A friend of mine has a very leaky steering valve that he wants to fix. I've done quite a few 2430's and 40's but unsure what the 2350 uses or looks like. Is it similar in design and repair?
Thanks, John
All the JD 20-55 series utility tractor power steering steering valves are similar except the very few later models that had hydrostatic steering. Even the model with open center steering are similar only with different(open center) control spools. Replacing only the seal under steering wheel may not repair hyd leak due to lower o-rings being faulty.
