620 PTO Fluid
Fordy20
Just bought a 620 that the PTO will turn the finish mower disengaged when first hooked up but after mowing will stop when disengaged even without the mower hooked up. I'm going to change the oil and see the manual recommends SAE 10W. Can Hy-Gard be used instead? Also for the hydraulic system?
Hyd gard will be fine for pto & hyd. That is what I use. See if you have tranny gear lube getting into it. A reseal job may be in your future. You can also check the pto clutch and brake adjustments.
