Part number
Mark-Ia
Can someone tell me what R58295 fits. It's a 4 cylinder engine overhaul gasket set. JDPARTS says it subs to another number and is a rear axle housing gasket.Not.
Take another look at your part number, many times I've gone done the same path to where you are, only to finally figure out I got a number or a letter wrong or transposed.
I think you are missing a letter and or another number in the part number cause if it is a gasket set it should start with RE then about 6 numbers with today's part numbers.
