Sister-in-law and her significant other came down to visit my MIL. They borrowed the 4010 for a while to load up some stuff to haul back to their home.
They came down and said it wasn't running right. Pulled it down to the lp tank and put in some propane. And put in maybe 3 quarts of oil in the engine. Went back to what they were doing and came back down and said it still wasn't running "right". Parked it.
This is all info from my MIL.
I went out today to do some things with the tractor.....loading things to haul off, leveling ground, etc.
The tractor would not turn over. Took off the battery and gave it a quick charge.
Still wouldn't turn over. Acted like it was locked up.
Got MIL to pull me a little ways with the pickup to see if I could get it started. Tried 7th gear going maybe 6 mph. Would slide the wheels about a foot before MIL and the pickup would quit pulling.
Pulled flywheel inspection plate off. Put in prybar to rock it back and forth. Not locked up but wasn't really easy to move either. Could not use the fan and pressure on the fanbelt to move the engine.
Pulled sparkplugs. All looked fine. No water in the cylinders.
Tried to use the starter. No go.
Got tired....decided to try the intertubes......
Where to from here????
Could it be the front hydraulic pump????
Or galled crankshaft bearing?
Or just a bad starter?
Please help......MIL needs a loader tractor.....:^)
