changing 4020 over to 2 12v batteries
bv
was thinking of putting 2 12 volt batteries on my 71 model 4020, any pics of how my cables will hook up? thanks again
Your 6 Volt batteries are connected in series, when you install 12 Volt batteries, connect then in parallel.
Cable from the (-) post on EACH battery to chassis ground, cable from the (+) terminal on each battery to the starter solenoid.
Yes one gets more amperage to starter with two 12 volt batteries. JD changed from two 6 volt batteries in series to two 12 volt batteries in parallel from factory on the 55 series rowcrop tractors
