JD 245 Front-End Loader - Dump Cylinder Diagram?
Dad has a 2550 Deere with a 245 (could possibly be a 240, as the tractor has incorrect 2555 decals) loader. The dump cylinders were both leaking, so we took them off to have them rebuilt. We have reason to believe that they both had been worked on before, and weren't put back together correctly afterwards.
Does anyone have or can anyone point us in the direction of an exploded diagram for one of these cylinders?
Serial #: W00245X005717*
After looking at the serial number, I'm betting it's a 245.
Thanks in advance!
(quoted from post at 21:26:21 12/27/16) Should be in PC1831 at the John Deere parts site.
Parts catalog link
Thanks for the reply, Bob. I tried searching your number (PC1831) in the catalog at that link...no result. Before I posted here, I also tried searching for the 245 loader...also nothing.
If anyone else can get in there, all I need (I think) is a shot of the exploded view of the cylinder, along with the part numbers to go with it.
Don't know why it won't work for you???
There's 6 bucket cylinders listed, so it would be best if you could look it up directly.
Does the site come up? what happens when you enter 245 in the model number search box, or 1831 in the catalog number search box?
radara
use the parts catalogue link that bob has sent you but only type in 245 and then search
do not type in any words like LOADER after the number.
the search will find that for you.
good luck
According to loader serial number W00245X005717 this should be correct bucket cylinder kit(key 18).
AW23334 KIT, SEAL ADD 47.03 USD
Does any one have picture of the carrier mounted on the tractor, interested in seeing how the back side it mounted and how it is mounted on to the frame. I have a JD 2240 and purchasing a JD 245 loader.
