So my intention was to install new bushings in the idler gear between governor and powr trol pump. I was noticing a whine when the pump was engaged. Got the pump off, removed the small pin holding the idler gear shaft, and started to pull the shaft out. Pulled the shaft out until it was against the flywheel. I now realize that I either have to remove the flywheel or remove the entire governor housing. Now seems to be a bigger project than I anticipated.
Which would be the easiest to remove with as little re-installation adjustment as possible? Or maybe I am better off putting it back together and living with the whine when I am using the powr trol pump?
