stoneridge
run a 4430 on a baler and loader. the hyds chatter and are very slow. was told I could run a line from the main pump directly back to spools and it will help with both problems. it takes the supply pump in trans out of the loop.any idea if this works or is a bad idea?
was also told it could be O-rings on supply lines to pump in trans that are allowing air to enter system. Pain to go into tranny but could do it if this is the problem.
