In addition IIRC ? I think there is an adjustment needed under a capnut on the left side of the unit ?
Yes, You can run a one-way cyl with the Powr-trol.
Hook up the hose from the "L" outlet on the cyl to the "L" outlet on the Powr-trol. Take off the cap nut from the metering screw on the left side of the Powr-trol, loosen the 3/8" jam nut and turn the screw "in" until it bottoms out. Tighten the jam nut and replace the cap nut.
