John Deere 830 3 cylinder
My 1st thought is control lever isn't adjusted to control shaft correctly. Notice slot in arm bracket encircled in blue. If it was my tractor I would adjust L/D mechanism following the several steps as outlined in a JD 830 tech manual. IIRC the adjustment procedure in tech manual addresses the correct lever to control arm adjustment.
