I think I've made a decision on this but I'd like input from the forum before I commit. There may be something I am not thinking of and I want to make the best decision.
I have a 1968 JD 2020 diesel. It has been a solid running tractor for the years that I have owned it. It leaks some hyd. fluid and it's not perfect but it has been reliable with good PTO, strong 3 Pt. lift, good sheet metal, etc.
The tractor's in a diesel engine repair shop right now. The engine is locked up. The shop owner pulled the oil pan and although he can't see everything the bottom line is it needs a rebuild. So this post doesn't get even longer I won't cover all the details but I am not interested in doing less than full rebuild. As I see it I have three options.
1. Have the shop rebuild the engine which will be $5,500 - $5,700. The upside to this option is that I get a fresh engine. The downside is my 2020 has the less desirable of the two injector pumps and I have no idea of how long that pump has been on the tractor, at least ten years. It works right now. I learned here, and the shop confirmed that a replacement pump, depending on who's numbers you use, will run me anywhere from $2,200 - $2,800. Used 2020's that I am seeing in the SE that are in what appears to be similar condition to mine are about $6500.
2. This option was offered by the shop. He says that in the past he has bought and installed 219 model JD engines that comes from a company that takes them out of 6000 series JD high boy sprayers. He says he's had good luck doing this. He gets the engine from a large supplier and they typically have less than 1,000 easy hours on them. He explained this in a lot of detail but summarized he says there is no used market for the sprayers and these engines are in tons of different equipment and have a solid record of reliability. Upside is the engine is a bit more powerful than the original, has a newer and available injector pump that comes with the engine, is from the late 80's to early 90's so it is a more modern design. Downside is that it is still a used, not rebuilt, engine. He made a very valid point in saying that if he lacked any confidence in these engines he wouldn't install it knowing the R&R falls to him if it's bad. The cost of this option is the same as rebuilding mine.
3. I sell mine as is and buy another used tractor. The obvious downside to this is I could get lucky or get junk, as I would look for one in the same general price range as options 1 & 2. I have always thought I might find a deal someday on a 1970's tractor in the 90 hp range but that same issues hold true of all used purchases, and they don't go as cheap here as they seem to in other parts of the country so I am tabling that for the future and sticking to something like I have if I go the used route.
So what would you do? As I said I am leaning hard in a direction but I'd like some input in case I am missing something.
