I have a 1951 A that I put new rings in last fall and had the head re-done. I put it on the dyno to seat the rings a bit. While it was running it would run ruff and loose power occasionally but came out of it. Thought nothing of it and took it home. Hauled the last of the corn harvest to town with it and ran fine. A few days later disced about 6 acres with it and it started running ruff and backfiring through the carburetor. Thought it was an electrical issue, replace some parts and it seemed to solve the problem slightly but never really went away. Finished my field and put it away. A few days later drove it from the shed to the shop and it ran terrible for 30 minutes then died. During that time it backfired through the carb and actually wedged the choke disc shut inside the carb so the lever would not move it. I rolled it into the shop and it sat for the winter. I have been trying to get it started this spring and get nothing. A small puff of white smoke is the most I get. I have checked and Re Checked the basics: I have good spark, I am in time, carb is spotless and getting fuel. Choke on or off has no effect, throttle position has no effect. One unusual thing is after cranking for several minutes. If I open the petcocks, #1 cylinder is hardly any fuel in it but fuel comes gushing out #2 petcock. I am not sure what else to look for. This tractor is my planting tractor to boot and pulling a 494A with this is more fun than the 4230. Any help would be appreciated. Thanks.
