It looks like our John Deere 4010 Diesel has the front frame rails, left and right, bent just a very little at the front motor mount location. It is hard to check real good to see if the frame rails are really bent because there is a home made frame welded to a Koyker loader. my dad made the frame part, to make it a quick mount loader and to make it stronger because the Koyker loader broke at that stiff arm mount to the frame. This was done in about 1965. We will have to find a way to check better to see if they are bent..
My question is if I need new frame rails, left and right, it looks like there are new one we can get. Are they good enough and have good fitment to the tractor. Is there any problem with the new ones? Are the new frame rails the same as original frame rails?
thank you stano
thank you stano
