Company Logo Shop Now
TractorLinks.com
Rear end noise 4230
mjbrown
04-15-2019 15:05:05
Rear end makes a clank noise when changing direction forward to reverse etc. Also happens when shifting to high or low range except when pulling a load. More so when warm. No noise otherwise when driving. Quad range open station no wheel weights. I didn't notice this noise before I had a dealer install a rops.
Thanks
ejr-Ia.
04-16-2019 10:06:36
 Re: Rear end noise 4230 in reply to mjbrown, 04-15-2019 15:05:05
It is your plant gears in the axle housing my 4020 makes that noise
ss55
04-16-2019 07:00:42
If it only happens when you reverse direction, check if the rims are sliding in the rim clamps.
Tx Jim
04-16-2019 03:24:57
Be sure both axle wedge bolts & outside rim to wheel bolts are all tight.
Tim S
04-15-2019 16:11:13
Or differential about to go out...you can peek into the bung hole at the upper right rear of the trans case and see a bit..maybe enough to identify the noise..
MSM
04-15-2019 15:35:56
It probably made the noise before the ROPS install....they mount directly to the axle housings steel on steel and tend to really reverberate any noises from the drive train. Only other thing could be loose wheel clamps
larryanderson
04-16-2019 03:16:25
 Re: Rear end noise 4230 in reply to MSM, 04-15-2019 15:35:56
The roll guard will multiply the noise but a clank is definitely not from roll guard and needs to be addressed.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
