Flywheel Installation
Having to split my 1010 again and going to reinstall the flywheel cause it shakes after the rebuild. Thought I did this correctly the first time but apparently not. With that in mind, is there any sort of trick to putting the flywheel/clutch on? I've been just bolting the flywheel in place to torque spec, the bolted on the clutch. Didn't see anything special in the manual when it came to the flywheel install. Am I missing something?
I'm gonna GUESS... #1, IF it matters which way the flywheel goes on it will be dowel pinned or the bolt pattern will only allow it it be installed the correct way. #2, What makes you suspect the flywheel is the cause of a "shake"?
The entire tractor just vibrates more than it did before I rebuilt the motor. Not much more to it than that. I'm guessing that the flywheel is just slightly off and thats causing the increased vibration.
