1954lincoln
I had the MT running this morning and this intermittent issue i have been having lately with the ignition system popped up. It was running what seemed to be fine is really not running well.
I have found that the back cylinder when the front plug wire is pulled will not run the tractor engine. When i pull the back wire and leave the front one on the plug it runs.
I have a good spark in the back cylinder and a weaker one in the front plug.
The compression in the back cylinder is 105 psi and the front 100 psi.
I noticed that the engine lacked power last week when i took it out.
I checked that the plugs were in tight.
