Mounting 4 row cultivator on JD A
pmarkel
Any reason why this cultivator shouldn't mount easily on a 49 A w/rollamatic front? Looking for the upper line up bracket and button if anyone would be interested in selling. Thanks,
Pete
My dad (and I, the flunky) ran the exact same setup (except the A had been converted to LPG) in Texas for many years. Handled it exceptionally well.
Did you find the upper line up bracket and button? I just purchased a 2-row cultivator and might have the bracket. Let me know if you didn't find it.
thanks, yes I still need the top bar bracket for the cultivator and the button that mounts on the upper pedestal of the tractor.
After you have driven the tractor into it and pulled the gangs in against the tractor and aligned the holes, be careful not to burn your arm on the exhaust pipe when you reach inside the right hand frame rail to put the bolts in. For some reason that is the first memory that comes to mind from the many times i did that job.
Bob,
If you still have one of those upper line up brackets for an A I would be interested in buying it. Thanks,
Pete
