I have a 1987 AMT Gator and cannot get it to start. It will turn over but will not fire. I have no spark at the plug, fuel is going to the carb. I have removed the coil and need to know how to test it and where to find a reasonably priced replacement. I have no problem re-wiring the entire gator back to conventional wiring thus eliminating all of the safety switches, un-necessary relays and circuit breakers, etc. Lights, etc., I can handle. Just not familiar with the stator methods. Can I use a standard after-market coil; if so, how is it to be wired into the existing harness.
Need some professional help here. thanks in advance.
