Have a 68 4020 that has two issues. One is there is a oil leak under oil cooler beside air cleaner. Looks like it's on underneath side of cooler. I have look from bottom side as good as I can, oil seems to be coming down from top. What is best way to get to this. I know there are several lines that go into hyd.pump close to there.
Went on a tractor ride Saturday, noticed that rear end seemed to have a lot of slack in it. Had throttle set at a speed with other tractors. When on a dirt road and had to speed up I would push down on throttle, but road had a few holes in it would sound like rear end was back lashing. There is a front end loader on this tractor, when loading with it, it will have a clink noise when going from forward to reverse. Rear end was tore down about a year ago due to bushing going bad.
Any ideas on what needs to be done to fix some of these issues would be apricated.
