My late model B has a clunking noise in the transmission, but only when I am in third gear. It sounds like a gear is missing a tooth. The manual says you have to remove the flywheel to get to the gear shafts. Is there a way to do this without removing the fly wheel? Can I do it from the other side by removing the the first reduction gear cover and clutch assembly? I seem to remember when I was a 0 or 10, helping my grandfather replace second gear in this same tractorm and we didn't take off the flywheel.
Also which gear would cause this noise only when in third? I would like to buy the gear now, so that I will have at the time I tear it down so I can do it all in the same day.
