4430 park cable
jwr_03
New User
I am trying to replace my parking cable on my 4430 power shift. If someone could walk me through the process step by step I would appreciate it. Pictures or videos are always good.
I have got the side console started. The top plastic is loose and side panel is loose around the top, but seems to be holding on the bottom somewhere.
I cannot get any knobs off any levers.
Thanks
Update:
I got to the cable in the side console.
Ok, so here is where my original problem started. My tractor started rolling when in park. I noticed under the cab the roll pin on the transmission lock was missing. I got that fixed then the shifter was stuck in park. If I loosen the clamp holding the cable (under the cab) it will shift out of park, but still rolls. I was told the cable could be stretched, so I was going to adjust it or replace it. Will this fix the problem?
I don?t know why it gets stuck in park or rolls.
Can someone help me?
Not likely that the cable stretched,, the missing roll pin was the beginning of your problem, then the latch in the console got out of place and locked the shifter mechanism up.. There is a strong chance that the roller on the park pawl is loose inside look at the pic in theSVcummmins post up above, #3 is the roller i'm talking about,,if your park will still not hold you will need to look at this,,it is possible to go down through the cab floor to get the top cover off.
That picture was kinda blurry, so I pulled it up. I assume you meant #2 roller (not #3). I'm not much of a mechanic. How do you go through the floor to get to the park pawl? Step by step details and pictures would be great.
