JD 40 Transmission
jerryinga
I have a JD 40 Tricycle with a noisy third gear pretty bad under a load I know I will have to split the tractor, but how much work is involved after that?
What will I be looking for a bad bearing or a bad gear. Is it fairly simple or will I be getting in over my head. (I am only a shade tree mechanic)
Is there a manual that will guide me
"[b:654c4848f0][i:654c4848f0]Is there a manual that will guide me[/i:654c4848f0][/b:654c4848f0]"
Yes.
<a href="https://www.ebay.com/sch/i.html?_from=R40&_trksid=p2380057.m570.l1313.TR6.TRC0.A0.H0.Xjohn+deere+service+manual+sm-2013.TRS0&_nkw=john+deere+service+manual+sm-2013&_sacat=0">SERVICE MANUAL SM-2013 JOHN DEERE 40 SERIES</a> TRACTORS AND CRAWLERS.
Information is in [b:654c4848f0]Group 20 Transmission and Differential[/b:654c4848f0] starting on page 130-20-1.
Hope this helps.
(quoted from post at 17:17:26 04/06/19) I have a JD 40 Tricycle with a noisy third gear pretty bad under a load I know I will have to split the tractor, but how much work is involved after that?
I have a copy of the Manual . where are you located in Ga I am in the Vidalia area. My email should be open if you want to contact me .
