jd 730 speed control plate
kurt v
Does anyone sell the fiber disc that fits inside the housing that bolts to the cowl, my handle fit inside the casting and against the friction disc? Or rebuilds them, just a matter of gluing the disc in place.
thanks kurt
casting no is af 3849 r in my parts book
This site(YT) has the part you're looking for. Look at top of the page then click on "John Deere" scroll to model 730.
TX Jim. this site does not show a pic but I would bet it's the wrong one, I need the casting like the one on ebay, the flat plates are wrong ones. the plates are the right shape but I need the counter sunk casting that my handle fits into. I have the casting just need the friction material.
thanks kurt
kurt v,
not that you will want to see this....but....deere prices it at $168.21..not saying that is the best option.....but at least it says its out there.....per your part number provided
also as a sub number
RE227872
thanks for the reply, the casting that I have is this one ebay no 332540621238, don't need casting just have to find something to replace the friction material.
thanks kurt
(quoted from post at 08:51:13 04/06/19) TX Jim. this site does not show a pic but I would bet it's the wrong one, I need the casting like the one on ebay, the flat plates are wrong ones. the plates are the right shape but I need the counter sunk casting that my handle fits into. I have the casting just need the friction material.
thanks kurt
My interpretation of parts catalog noting tractor serial number indicates you need key 17B which is AF3847R with friction plates which is the part YT is showing.
Mr Tex Jim, that is not the throttle setup that is I my 1960 730 ser no 7324936.
I have no idea how to do pics so I could show you.
if you look at the ebay listing I posted it will show my throttle plate.
still thanks for helping
kurt
I don't know is this is a "correct" restoration, or a working tractor, but for a working tractor, some years ago a friend's 720 had this issue, and I cut 2 circles of heavy leather from the "uppers" of an old work boot and punched 3 holes in them, one in the center, and two for the pins.
Rather than being slotted and glued to the center casting, the leather discs rotate with the levers because the pins pass through them, and wear against the center casting, providing the needed friction on the throttle.
So far the "fix" has held up just fine, although he doesn't put a whole lot of hours on the tractor, so time will tell!
If you don't want to $$$$ for a new casting, and it isn't a perfect restoration it mite be worth a try.
On the other hand, it doesn't look like the hood support changed over the years, I wonder if the newer-style steel plate with the frictions would be a bolt-in replacement? The lever was changed, wonder if that was a "fitment" change, or just to a bigger flange to "hide" the area around the friction pad plate?
Thanks Bob, I have some header gasket material that I'm going to use to see how it works. Not a super resto I just like to do things the right way the first time.
Case in point fuel problem I had was from PO putting a 8n fuel bowl in the by pass adapter below the tank and crushing the tube and screen when he screwed in the fuel bowl, I would get fuel when I bled filters but not enough to run motor after it used up the fuel in the filters. Drove me nuts till I took the bowl out to put the correct one in.
thanks all for your help
kurt
I looked at the Ebay listing. It states 70 & 720 but not 730. If you choose to you can email me photo & with your permission I'll post the photo for you.
Mr Jim, my parts book jd-p-pc532 shows that it's for 7214900 and up and is for the cash cowl ar 20928 r 7300000 up.
I don't know how to do any of the picture stuff, don't even have a cell phone.
thanks kurt
