Hay maker2
John Deere 4240 Quad
The three point will only raise if the control lever is all the way back. As soon as I let go of the lever it will instantly move back to the lower position kind of like it is spring-loaded which it is not. The rockshaft is either up or down and nothing in-between.
It does not make a difference where I sent the Min –Max (L-LD-D) too.
I have not remove the linkage from the control lever on the side of the valve housing to see if the binding is internal or external to the control housing. If it were external, I would think that I could set the rockshaft to any position, which I cannot.
I replaced the load control shaft last summer as it was leaking. I have not used the rockshaft after that.
Obviously, something is majorly out of adjustment. Is there a chance that when I pulled the load control shaft out and replaced it something dropped out of position?
