MT oil pressure
What is a good oil pressure for the MT? My rusty gauge has the needle showing straight up and down when running. I tested this mark with a carb pop off pressure pump and it would be around 30 psi for the oil pressure. I can pump up to 50 psi with the needle location to the right.
"[b:654c4848f0][i:654c4848f0]What is a good oil pressure for the MT?[/i:654c4848f0][/b:654c4848f0]"
Take a look at the information below.
Hope this helps.
Thanks!
The reason i was asking is that I'm starting to get some noise from what i believe is the wrist pins. I have a stethoscope that is used for isolating noise. Just making sure there is enough oil getting around. Could it be piston slap from the rings and how can i tell the difference? Compression check?
