51 A ventilator gear removal
RedJD
Trying to remove the gear on the ventilator pump on my model A 1951, took the snap ring off used a clamp behind puller on it and tighten it as much as I could with a hand wrench , would not budge. I'm guessing I need to find a torch to heat the gear If anyone has done this , how did you get it off? Also are the parts available to rebuild it , I believe the 2 springs are broken because its pumping oil up the tube and slinging out the fan. Thanks
I would hesitate to apply much heat to the (likely hardened) gear.
How about a press?
Looks like the springs (B2651R) are still available from DEERE, the vane nd the spring retainer are not.
