First time with a JD two cylinder. Seller claimed it ran last spring, tried pull starting at sellers location, no start. Got it home set points and timed magneto, pulled to try to start, no go, dropped float bowl, carb all rusted and gunked up. Rebuilt carb but now the motor will not turn AT ALL, drained oil and got 2 pints of water first then slate gray oil and lots of sludge. Pulled crankcase cover off, have yet to drop oil pump but drive coupler "looks" to be in place. Am concerned that all the pull starting was taking place with no oil pressure, man on tractor said it was bouncing up and down on the gauge. It's 6 volt system and after I rebuilt the carb it cranked over maybe 3 revolutions and stopped, now I can't move it at all. So much sludge pickup screen is probably plugged. Is it seized up or could something else be causing the drag on the crank to lock it up on the clutch side? Thanks, sorry so long but wanted to put out as much info as possible, 1946 A, electric start 6 volt, before I took the cover off the crankcase I could take a huge screwdriver in the teeth of the flywheel and leverage against the starter nose and turn the flywheel ever so slightly.
