JD 2440 electrical issues
Codybill
New User
I have changed the starter, ignition switch and a couple relays. Cables are new along with battery. I can jump across the battery and it will spin, and power is leaving the ignition switch but not getting to starter. Any suggestions?
Buy a voltmeter! Check for connections/continuity across nuetral safety switch on top, front of rockshaft housing.
Cody,
Had the same issue with a 2440 awhile back. Found the connection on the key switch was rusty which wouldn't send power to the starter solenoid. If I put the tester on the switch terminal it would show power but not if I tested the wire eye directly. Took the wire off and sanded the connection and it worked fine. Good Luck!
John
