1. Thanks tlock0331 for posting back on your 4320 results.
2. Congrats Tim S on your diagnosis.
I went back to the original post to review Tim?s words because I recalled at the time I did not understand them.
Remove and cap the diff lock line before you tear it down,,that will prove the diff lock valve is not leaking a bit of pressure to cause a bit of drag,,
Can you explain a little about ?drag?. I guess I don?t understand how the differential lock works. Thanks.
Paul
Paul
