3010 lift control lever
Olliejunkie
Anyone got a cheap one. Deere wants $144. I will probably weld it back together but thought I would check here first.
(quoted from post at 00:26:16 03/31/19) I would try Martin parts and repair or all states ag
parts they would have a used one I bet
I will probably weld mine and continue to look for one. Thanks for the suggestions. Kind of a weak design. Mine was bent. I tried to straighten it when it snapped. Started by trying to lube the cable. I need to replace it or get it freed up.
It's a good idea for all of us to spray some penetrating oil on the cable from time to time...it will soak into the housing and keep it free.
(quoted from post at 11:08:22 03/31/19) They surface on EBAY somewhat frequently as well if you dont need one tomorrow....
I welded it. I was going to fish plate it but I think it will work if I get the cable loosened up. Put a bunch of kroil on it.
