Re: Don?t you hate it
You're correct JD parts doesn't still have box labeled "where used" but you can enter part # in parts search & get similar results. The "65" listed under results is the number of implements listed below that utilize the part # I chose.
Bt golly, TxJim. you're right. Surprisingly, just entering a part number does seem to do a "where used" search. Who knew? Nothing indicates to me
that's what it's going to do. I supposed that would take you to the spec for the part, as it did on the previous site. Still, I know for one trial part
number I entered, an engine short-block, it showed some uses that would not be right. A 3-cylinder engine for sure does not use the same short-
block as does 2-cylinder engine.
