Today's hydraulic fluid in a 2 cylinder
kwoods
I'm wanting to disc with my G this spring. The power-trol manual calls for the same oil used in the engine to be used in the hydraulics. The problem is is that the disc I'll be using has modern hydraulic oil in the cylinder, hy-gard I believe. I don't want to mix the two oils for obvious reasons so I was wondering if I can use the modern oil in the tractor?
