4020 gas - no fire
isuvinny
I don't think I am getting any fire on my 4020 gas. I have fuel to the carb. I pulled the wire from the center on the distributer and touched to the frame - there is spark there. The distributer cap looks ok?? I filed the contacts a little but they sure look good. This has electronic ignition on it, so there are no points. What do I do now? Pull a spark plug and see if there is fire there? Thanks for any suggestions.
Check for spark at the plugs with a gap-type spark tester.
If no spark there, check for spark out of coil high-tension lead, also with a gap-type spark tester.
