4440 draft and load control adjust
Anyone have a list/photo copy/ picture of the adjustment for a4440 load controlshaft nut iniside the transmission housing? Mine needs done and I seem to have lost/misplaced my factory manuals. Iremember that you set the draft to minium and pull back on lever to like 5 to see start to lift then move tomax and see lift at 9 but There wasa little more to it than that. thanks.
I don't remember but I can look tonight. Be sure the socket attached firmly to the extension, I have mine welded on.
Ditto on securing socket on extension. To properly adjust L/D linkage on JD tractors such as 4440 there are ""several steps"" that must be performed in order to get 3 pt adjusted correctly
yes several steps; I wish I could find my manual. thanks for the help I de recall and I have located my extension with welded on 9/16!!
