tysmobiletractor
Got a good 3010-whats been done:
Checked TDC - firing order is on - timing is good
New - points - coil - cap - rotor - plug wires
Lots of fuel supply from tank - pump - through filter to carb
Carb has been removed disassembles - soaked - new kit
air breather is unhooked - so not a air supply issue
good compression
It will start and chug along at about an idle.
Give it any throttle and it wants to die.
It will idle for a bit and then acts like its running out of fuel.
Give it throttle and it will occasionally backfire - through the muffler - just doesn't make sense.
This is a nice clean painted tractor.
You know what I mean- not a dirty old nasty one.
These symptoms have come on slowly over time- and just seem to get worse!
Glad to hear your thoughts.
Thanks
good compression
Thanks
