jd 730 electric start diesel gen
kurt v
Just got the 730 and it's got a alt on it that's 12 volt, tractor is a 24 volt system, how can this work? Have not run tractor yet but will be looking for a 24 volt gen.
thanks kurt
Let me try and state this a little better,, tractor came to me with a 12 volt alt , will this set up work?
I don't see how it can but till I can find the 24 volt gen can I run tractor, need the water pump working.
I don't see how it can but till I can find the 24 volt gen can I run tractor, need the water pump working.[/quote]
As we both know, the tractor left the factory with a 24 Volt system.
But that was a long time ago, and "stuff happens".
It's POSSIBLE someone has also converted the starter to 12 Volts, and reconnected the battery groups in parallel.
Or, if a series-parallel switch has been installed, a 12 Volt alternator can charge the batteries, yet there will be 24 Volts available to the starter.
Do you know for SURE it's a 24 Volt alternator, a 24 Volt alternator can be modified on the inside to generate 24 Volts, and still have the same outside appearance and a 12 Volt part # or I.D. sticker.
Or, a person who didn't know what they were doing could have installed a 12 Volt alternator without realizing it was a 24 Volt system.
Kurt,
I have a Delco 24 volt generator (never used Army, I think) that I bought surplus (actually 2). Send me an email and I'll measure and take photos of it and my 730 generator that is original to the tractor and send if you are interested. Price is $50 plus shipping.
(quoted from post at 20:26:32 03/19/19) Kurt,
Is that 24V Army generator a floater or connected to chassis ?
