300B Axle Housing Torque Specs
Well I'm working on our JD 300B again this time the axle snapped, after tearing into it found the axle appeared to have been
particially broke for sometime probably before we purchased it and someone had already been in it once before (had the wrong axle
in it) got the proper parts and back together but I have not found anything on the torque specs are for the bolts that hold the
axle housing in place (that was fun getting that lined up and stabbed in place) I have read the Tech book several pages either side
of the assembly pages for installing everything back into the housing but I cannot find anything on installing the axle housing
back onto the tractor and what the torque specs are for the housing bolts
Is it listed in the specifications section at the end of the power train section? I know that is where some are, this is assuming you have a real John Deere manual, or reprint of one. If not does your manual have a generic torque chart? They are usually in the front section, many JD manuals have them as well. Those charts are to be used where specific torques aren't written in the procedure or listed in the specifications section.
