lakenseagt
New User
I have an early 1964 3020 Power Shift with a hyd oil cooler like the following.
The cooler leaks so I'm trying to figure out if I can replace with later style cooler like key 22 below. At one time Deere had a kit available to do the conversion, but NLA. The later coolers are available from aftermarket, but with no instructions.
Questions:
The earlier cooler only has an opening at the bottom of the cooler that slides into hose (key #36 in earlier style) that connects to pump housing via a 90 elbow fitting. The later cooler style replaced that opening at the bottom of the cooler with a closed tube that extends down (just above #34 on later style). Maybe this closed tube is only to support the cooler. If so, what do I do with the old hose and connection to pump? Do I plug it?
Also the later cooler style has a line coming out bottom that has a 90 bend and then connects to hose (key #28 in later style). Where does this hose go?
Any help would be greatly appreciated.
Questions:
