Denmarkmaine
Ran my 300 industrial today and it started to get in the red zone.i have installed new water pump, new thermostat, radiator is clean, coolant is flowing fine. Any other ideas? It was only 34 degrees today
? Are you meaning head gasket?(quoted from post at 15:11:55 02/16/19) Sounds like a hole in a liner.....
Is it ok to run for a while if I do find exhaust gases in the coolant? Till I get time & $$ to fix?(quoted from post at 17:32:46 02/17/19) To David G's and Tim's point on exhaust gases. You asked early on if a NAPA block tester kit would work on a hole in a liner. Yes, it should. Get one this week and try it, it may pick up gases even though you haven't seen bubbles in the coolant. If the test is positive, you know it needs a teardown.
(quoted from post at 10:25:08 02/18/19) I wouldn’t do it myself. Was hoping it wouldn’t be that much. Ouch
