Any suggestions on routing the wiring for a rear work light on a 5105 (or 5205)?
I have a rear light attached to the top flasher assembly bolt on the ROPS. It appears to me that the wiring from the light should run down the inside of the ROPS and end up under the seat to connect to the matching black and purple wires. The top part is easy - there is a hole for the wiring in the ROPS between the two bolts which attach the flasher assembly to the ROPS.
What do I need to do to get access to the bottom of the ROPS?
