Company Logo Shop Now
TractorLinks.com
3020 Power shift hydraulic drain plug locations
lakenseagt
02-11-2019 10:50:49
I'm in process of changing hydraulic fluid in my 1964 3020 gas power shift. The manual shows 2 drain plugs. I found the one further back. For the front one, there are several hex heads of the same size. I don't want to remove the wrong one by mistake and cause some problem.
Can anyone describe or post a pic of the drain plug location??
Thanks in advance.
Dennis
lakenseagt
02-11-2019 19:17:29
 Re: 3020 Power shift hydraulic drain plug locations in reply to lakenseagt, 02-11-2019 10:50:49
Thanks to Tx Jim, Mike M, Kansas4010 and SVcummins for the quick responses and tips.
I'll probably get a chance to look for it again on Wednesday.
My hydraulic oil cooler has had a slow leak for a few years that has gotten worse. I had taken it to a radiator shop one time, but they said it didn't leak. Maybe they didn't put enough pressure to it.
In the past couple months, the fuel line had rubbed a slit in it (near the hydraulic pump) and the radiator was leaking at the top tank joint (2nd time), so I decided it was time to replace some $$$ parts.
SVcummins
02-11-2019 17:03:56
Mike M
02-11-2019 12:13:21
Don't forget to clean the suction screen.
Kansas4010
02-11-2019 12:38:02
 Re: 3020 Power shift hydraulic drain plug locations in reply to Mike M, 02-11-2019 12:13:21
What he said. It's the plug right beside the axle housing.
Tx Jim
02-11-2019 11:15:20
Welcome to YT
Drain plugs(key 24) should be the same 1-1/4'' hex size.
