john deere 530
working on my 530 and found a broken piston skirt below the bottom ring. ran good but needed to change my oil pressure regulator
as it was cracked and causing low oil pressure. i am looking for a set of M&W pistons for this. any ideas on where to find them?
(quoted from post at 12:26:07 02/10/19) working on my 530 and found a broken piston skirt below the bottom ring. ran good but needed to change my oil pressure regulator
This shop had a CNC mill and they will make any piston you want.
http://www.external_link.com/pistons.html
This shop uses a CNC mill and they will make any piston you want.
You may try to get in touch with ray at extreme tractor parts in North Carolina to get a custom set made or martins repair in Pennsylvania.
