Author |
[Modern View] |
krevansdc
02-10-2019 18:41:40
Hi All My first post here, I just bought a 301-A tractor, serial # 301AD 331531T. How can I tell if this tractor is supposed to have a reverser or Hi-Low and what year would this tractor be? Thanks!
Tx Jim
02-13-2019 03:42:32
Re: 301-A in reply to krevansdc, 02-10-2019 18:41:40
R63438 shows to be for tractor less reverser
krevansdc
02-13-2019 19:25:37
Re: 301-A in reply to Tx Jim, 02-13-2019 03:42:32
Great, thank you Tx Jim. I appreciate the info!
Jim.ME
02-12-2019 12:09:29
Get the casting number as TxJim asked. They were available with or without a reverser. Your tractor may never have had a reverser.
krevansdc
02-12-2019 18:28:38
Re: 301-A in reply to Jim.ME, 02-12-2019 12:09:29
The casting # is R63438 (top #) and below it; T42716. Hope this gives more usable info.
Jim.ME
02-11-2019 11:37:01
No later than 1978 by the serial numbers TomIn posted, might even be 1977. The year sold, or purchased, is not always the same as the year it was built. New and unsold could meet bid specs, all depends on how the spec was written.
TomIn
02-11-2019 07:13:00
My Hotline Farm Equipment Guide shows the beginning serial number for JD 301 - 301A models to be314230 for 1979 and 341902 for 1980.
ET
02-11-2019 11:11:11
Re: 301-A in reply to TomIn, 02-11-2019 07:13:00
What year is this tractor I have with serial number 303521? The state purchased it in 1979. Low bid would leftover tractors.
Jim.ME
02-11-2019 05:06:16
Like TxJim, I saw no reference to a hydraulic Hi-Lo. What is the dash marked under the lever? What does it do when you shift it? Or is this unit "dead" so you can't operate it to tell? Is there more to the story? This just seems like kind of a strange question at this point, to me.
Tx Jim
02-11-2019 04:29:18
Welcome to YT
After inspection of PC 1429 for 301A I see no reference to hyd hi-lo. What's the casting # on this tractors clutch housing?
ET
02-11-2019 04:20:06
I have a 79 301-A in my shop now, the serial number is 303521. Your tractor has to be 80 or newer.
Tim S
02-10-2019 19:02:25
It could be ether way,but not together..
krevansdc
02-12-2019 10:51:37
Re: 301-A in reply to Tim S, 02-10-2019 19:02:25
Thanks much, the responses have helped with determining the year. I only ask about the reverser or Hi-Lo because where the reverser lever would be on the dash, someone has installed a push button switch that is used to start the tractor, I assume that from factory the key switch is used to start the engine??
