John Deere 60 leaks rear end lube into pto compartment
4010 puller
Hi guys I noticed that draining pto oil on 60 that
compartment is still getting oil in it, looks to be
heavy gear oil. Is there much to changing seal
between rear end housing and pto housing?
Thanks
(quoted from post at 06:39:20 02/08/19) Hi guys I noticed that draining pto oil on 60 that
Thanks
just did one last week. Rockshaft housing has to come off and there should be a little gear pump housing back there with a bushing and two seals (or one JD original). Not too bad but time consuming
Bushing is a4795r and seal is aa5247r both available through deere
Did pmarkel's pictures answer your question?
Pump is on pto input shaft.
