Anthony Poole
New User
Tires will spin both directions when in the air. removed all plugs and plugged back in all ok. CHecked fuses and relays, replaced some bad fuses. Pulled column and checked shift lever, had two plugs coming out of it, One has 3 blue wires and one white (maybe). When unit on all three light up one for fwd one for neutral one for rev.. Other harness has one blue that lights up for rev. I think rest go to speeds on trans speed valve body. Opened valve body and checked the fwd nue and rev solenoids, wires good, but when put in fwd one solenoid lights when in neutral none, and when in rev two light up checked power and 13v on one and 4 volts on the other. Im thinking possible shift lever. any thoughts or checks? The fwd wire goes from lever to trns but the neu and rev go though the fuse box.
