HA92 Power unit
gasket set was hard to find for case D series engine. Victor was original. napa and others not available even with fel-pro. While checking for other parts called Summit Racing , they are FULL line fel-pro gasket supplier. Got case DC head set for about $70.00 Need cubic inch displacement. and other information as counter guys were not farm raised.
Getting old, cannot recall , is HA92 2 cylinder or 4? I have a good 4 cylinder waiting to make small tractor.
Victor made the gaskets. When I was looking for one I still worked Dana/Victor and I knew the Victor engineer assigned to John Deere and he told me that Deere had dropped those gaskets then and that was before the year 2001.
For your gaskets try Olsens Gaskets in Wa state If they don't stock them they will make them for you, but going to be spendy 360-871-1207,The manifold gaskets MIGHT be the same as a 1010 gas. Piston could be found at a salvage yard possibly. That engine was used in a model 25 combine, rings, maybe try Otto engine works,they make rings for the old hit/miss engines maybe they could make a set for you.
