Kill switch on wico x
36 A
I need to wire a kill switch on my wico x mag for a pull this weekend . What would be a good way to unplug it !
While a normally closed plug/unplug 12 volt power feed is fine for a battery powered ignition kill method, on that mag you need a normally open set up which if closed grounds out the kill switch terminal on a Wico X Mag.
John T
I have seen them used before and they are designed to pull out fairly easily to CLOSE the circuit (IE ground the mag to kill the spark). One end to frame ground other to the Wico's kill terminal/stud yayyyyyyyyyyyyy
John T
